01-22-2006 08:30 PM - edited 02-21-2020 02:13 PM
Hi All,
I can set up a vpn connection using an ip pool of valid internal ip address's (ie internal network 10.10.10.0 ip pool 10.10.10.30~50). Everything works fine, access to other pc's on this subnet etc.
However if i try to set using an ip pool of 10.10.11.1~254) I can connect through the vpn but am unable to see any other pc's, etc on the local network?
Is there a rule I am missing somewhere?
Any help appreciated.
01-23-2006 05:00 PM
Well a couple of things to check here one is your pix the default-gateway/is there a route to the pix for the 10.10.11.x network. Two is there an access-list in place preventing 10.10.11.0 network.
It would be helpful to see your configuration.
Patrick
01-23-2006 08:02 PM
Hi Patrick,
Here is the current config.
PIX Version 7.0(1)
names
interface Ethernet0
nameif Outside
security-level 0
ip address 192.168.10.253 255.255.255.0
interface Ethernet1
nameif inside
security-level 100
ip address 10.10.10.253 255.255.255.0
interface Ethernet2
nameif DMZ
security-level 50
ip address 131.131.131.253 255.255.255.0
enable password XCiL6fXTNO9qj5.B encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
domain-name wtm
ftp mode passive
clock timezone EST 10
access-list Outside_access_in extended permit icmp any any
access-list inside_nat0_outbound extended permit ip any 10.10.10.224 255.255.255.240
access-list Outside_cryptomap_dyn_20 extended permit ip any 10.10.10.224 255.255.255.240
pager lines 24
logging asdm informational
mtu inside 1500
mtu DMZ 1500
mtu Outside 1500
ip local pool Dial-In 10.10.11.1-10.10.11.239 mask 255.255.255.0
monitor-interface inside
monitor-interface DMZ
monitor-interface Outside
asdm image flash:/asdm-501.bin
asdm location 10.10.10.224 255.255.255.240 inside
no asdm history enable
arp timeout 14400
global (Outside) 10 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 10 0.0.0.0 0.0.0.0
access-group Outside_access_in in interface Outside
route Outside 0.0.0.0 0.0.0.0 192.168.10.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
group-policy try internal
group-policy try attributes
dns-server value 10.10.10.16 10.10.10.2
username testuser password 98ZeS29m9xvCI4tR encrypted privilege 0
username testuser attributes
vpn-group-policy try
http server enable
http 10.10.10.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map Outside_dyn_map 20 match address Outside_cryptomap_dyn_20
crypto dynamic-map Outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map Outside_map 65535 ipsec-isakmp dynamic Outside_dyn_map
crypto map Outside_map interface Outside
isakmp identity address
isakmp enable Outside
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp nat-traversal 20
telnet 10.10.10.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
tunnel-group try type ipsec-ra
tunnel-group try general-attributes
address-pool Dial-In
default-group-policy try
tunnel-group try ipsec-attributes
pre-shared-key welcome
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect dns maximum-length 512
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
Cryptochecksum:40cb58ee8d1653e2f4929ffedcaaa126
: end
