VPN connection works, but cant access inside network.
I have a pix501 on the edge of a remote site. I have a vpn tunnel connection, however I cant seem to access anything on the inside.
I have my config shown below-
AKCPIX00(config)# sh run
: Saved
PIX Version 6.2(3)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxx encrypted
passwd xxxxxencrypted
hostname Pixydust
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
fixup protocol sip udp 5060
names
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside (ip address) 255.255.240.0
ip address inside 192.168.1.5 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 (ip address) 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.1.100-192.168.1.130 inside
dhcpd dns 192.168.1.10
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
ip local pool akcpool 10.0.0.1-10.0.0.10
access-list 101 permit ip 192.168.1.0 255.255.255.0 10.0.0.0 255.255.255.0
nat (inside) 0 access-list 101
sysopt connection permit-ipsec
crypto ipsec transform-set akcset esp-des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set akcset
crypto map akcmap 10 ipsec-isakmp dynamic dynmap
crypto map akcmap client configuration address initiate
crypto map akcmap client configuration address respond
crypto map akcmap interface outside
isakmp enable outside
isakmp key ******* address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local akcpool outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup akcgroup address-pool akcpool
vpngroup akcgroup dns-server 192.168.1.10
vpngroup akcgroup default-domain password
vpngroup akcgroup idle-time 1800
vpngroup akcgroup password *******
Cryptochecksum:xxxx
: end
Re: VPN connection works, but cant access inside network.
Your configuration does not show any access list, please check your access list for any specific deny statements.
You might look into enabling NAT traversal, it doesn't look like you have it enabled.
You can do this through the PDM under configuration/vpn/policies. or in the command line with syntax as follows: isakmp nat-traversal 20.
Good Luck.
I had the same issue and follow your suggestion and put the nat-traversal 20 line and it works.
Can you tell me what that command does?
Thank you much.
Uriel Naranjo
94
