VPN CONNECTIVITY PROBLEM
I am am using pix as a VPN gateway & setup up the Remote access vpn on my PIX.
Now my problem is that if I assign a ststic ip address to my remote windows machine with Cisco Secure VPN Client ,then it unable to connect to my gateway(i.e. PIX).
And when assign the ip address through DHCP to my remote windows machine with cisco VPN Client then it make the VPN tunnel.
Any suggestion ???
VIjay
Re: VPN CONNECTIVITY PROBLEM
Hi Vijay,
What version of the Cisco Secure Client are you using? Are you saying when the machine has a Static address that it cannot connect at that time and if the same machine is assigned a DHCP assigned address then it does connect?
Aamir
Hi Aamir ,
I am using 3.6.5 Release of VPN Client.
You are right when the machine has a Static address that it cannot connect at that time and if the same machine is assigned a DHCP assigned address(access Internet through Dial up connection) then it does connect?
My PIC COnfiguration is :----
wr ter
Building configuration...
: Saved
PIX Version 6.3(2)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxencrypted
passwd xxxxxx encrypted
hostname proactive
domain-name proactive.com
clock timezone IST 5 30
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 202.54.15.1 vsnl
name 209.235.192.125 misra
name 64.58.79.230 yahoo
access-list proactive_splitTunnelAcl permit ip host 192.168.10.100 any
access-list inside_outbound_nat0_acl permit ip host 192.168.10.100 192.169.10.0 255.255.255.192
access-list outside_cryptomap_dyn_20 permit ip any 192.169.10.0 255.255.255.192
access-list ping-access permit icmp any any
access-list ping-access permit udp any any
pager lines 24
logging on
logging timestamp
logging trap errors
logging host inside 192.168.10.68
mtu outside 1500
mtu inside 1500
ip address outside dhcp
ip address inside 192.168.10.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool vpn-pool 192.169.10.1-192.169.10.50
pdm location 192.168.10.4 255.255.255.255 inside
pdm location 192.168.10.22 255.255.255.255 inside
pdm location 192.168.10.100 255.255.255.255 inside
pdm location 192.168.10.3 255.255.255.255 inside
pdm location 192.168.10.68 255.255.255.255 inside
pdm location 192.168.10.40 255.255.255.255 inside
pdm location 192.168.10.69 255.255.255.255 inside
pdm location 192.168.10.48 255.255.255.255 inside
pdm location 192.168.10.246 255.255.255.255 inside
pdm location 192.168.200.0 255.255.255.224 outside
pdm location 192.169.10.0 255.255.255.128 outside
pdm logging critical 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group ping-access in interface outside
route outside 0.0.0.0 0.0.0.0 203.122.61.16 1
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:01:00 absolute
timeout xlate 0:01:00
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.10.4 255.255.255.255 inside
http 192.168.10.22 255.255.255.255 inside
http 192.168.10.100 255.255.255.255 inside
http 192.168.10.3 255.255.255.255 inside
http 192.168.10.68 255.255.255.255 inside
http 192.168.10.69 255.255.255.255 inside
http 192.168.10.48 255.255.255.255 inside
http 192.168.10.246 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
vpngroup proactive address-pool vpn-pool
vpngroup proactive dns-server vsnl 202.54.15.30
vpngroup proactive default-domain domain1
vpngroup proactive split-tunnel proactive_splitTunnelAcl
vpngroup proactive idle-time 1800
vpngroup proactive password ********
telnet 0.0.0.0 0.0.0.0 inside
telnet 192.168.10.100 255.255.255.255 inside
telnet 192.168.10.4 255.255.255.255 inside
telnet timeout 20
ssh timeout 5
console timeout 0
terminal width 80
Cryptochecksum:xxxxxx
: end
[OK]
120
