You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
VPN fails when using Cell Card - MacBook Pro Intel
I am having problems connecting to VPN using a MacBook Pro Intel with the Verizon Cell Cards. Any known issues with VPN and MacIntosh?
  • Other Security Subjects
Re: VPN fails when using Cell Card - MacBook Pro Intel
I'm having this problem as well. Initially it looked like UDP 29747 was needed (blocked on our PIX), but even when I do connect, the connection drops at 5 seconds with an "IKE Delete:...No Reason Provided" on the concentrator.
I have used both VZW and Sprint data cards with Cisco VPN without issue. My latest around was on 10.5 with the latest Cisco VPN client for Macintosh.
My broke in October I believe. It had worked for many months prior to that.
Do you know if it's still working for you?
151
