VPN from 3640 to Watchguard Firebox X Edge Problems
I'm having problems establishing a VPN tunnel between a 3640 and a
firebox X Edge.
It seems to die during Phase 1 even though the X Edge is setup for
3DES & SHA hashing.
The cisco Local LAN is 192.168.100.0/24 and the X Edge is
192.168.1.0/24.
Any help would be much appreciated.
Please reference this Google Groups post for details (log + config):
http://groups.google.com/group/comp.dcom.sys.cisco/browse_thread/thread/2942917d897054b3#
-- James
1 REPLY
Re: VPN from 3640 to Watchguard Firebox X Edge Problems
James,
Phase 1 failure could be to a numner of things:-
1) Incorrect identity - IP address, Cert
2) Incorrect pre-shared key, is used
3) Incorrect Hash
4) Incorrect Encryption
Just to name a few, can you post the settings for phase 1 and 2 for both devvices?
Andrew.
118
