VPN+FW Needs SSH to WAN and Telnet to Lan
I need to allow ssh to the Wan Interface of a 1750 and allow telnet to the Lan Interface. I have IOS w/Security (FW+VPN) installed and have created a tunnel and set up firewalling between 2 1750's. I Can Ping and Use Resources on each remote network but can only access router at the Lan Interface via SSH. Need to be able to access a remote router via the Lan interface through the tunnel via telnet as well as copy the startup config from a remote router back to a tftp server. Any help would be appreciated. Current access lists are as follows:
interface Ethernet0
description connected to Internet
ip address 172.16.20.20 255.255.255.0
ip access-group 102 in
half-duplex
crypto map cm-cryptomap
interface FastEthernet0
description connected to EthernetLAN_1
ip address 64.x.x.x x.x.x.x
ip access-group 101 in
ip inspect FastEthernet_0 in
speed auto
router eigrp 100
network 64.x.x.x x.x.x.x
network 172.16.20.0 0.0.0.255
no auto-summary
no eigrp log-neighbor-changes
ip kerberos source-interface any
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
access-list 100 permit ip 64.x.x.x x.x.x.x 64.x.x.x x.x.x.x
access-list 101 permit ip any any
access-list 102 permit udp host 172.16.10.10 host 172.16.20.20 eq isakmp
access-list 102 permit ahp host 172.16.10.10 host 172.16.20.20
access-list 102 permit esp host 172.16.10.10 host 172.16.20.20
access-list 102 permit ip 64.x.x.x x.x.x.x 64.x.x.x x.x.x.x
Jerry Roy
jroy@axcelerant.com
1 REPLY
Re: VPN+FW Needs SSH to WAN and Telnet to Lan
Looking at the information you’ve provided it looks good to me. I think Cisco is going to need to troubleshoot it with you.
271
