10-25-2007 06:41 AM - edited 02-21-2020 03:20 PM
I have an ASA5510 that I am trying to setup VPN on. I need to allow home users access inside our network. I have tried going thru the VPN wizard several times and just cannot seem to get it working. I am using the Cisco VPN client, latest verision.
I am enclosing the latest configuration which also has a show version at the end of it.
Any help would be greatly appreciated.
10-25-2007 06:59 AM
Firstly, you always want your vpn pool to be different than your inside network.
access-list inside_nat0_outbound extended permit ip any 10.19.1.0 255.255.255.0
ip local pool VPN 10.19.1.100-10.19.1.254 mask 255.255.255.0
Also add..
crypto isakmp nat-traversal
Also, are you trying to vpn to the inside interface?
crypto map inside_map interface inside
crypto isakmp enable inside
10-25-2007 07:16 AM
Thank you for your help.
I am at home and want to have VPN access to the inside networks.
Seth
10-25-2007 07:21 AM
These lines should say "outside" as you are vpn'ing to the outside inteface of the asa.
crypto map inside_map interface outside
crypto isakmp enable outside
10-25-2007 07:32 AM
I did correct the config with the commands you gave me.
I tried to connect with the VPN client and still cannot. I was curious about the pre-shared key. Am I supposed to enter that in the client somewhere?
Seth
10-25-2007 07:36 AM
Yes. You need to enter the group name "VPN" and the pre-shared key or "password" under the group authentication section of the cisco vpn client.
10-25-2007 07:37 AM
Yes you need to have the Pre-shared key in the VPN Client. When you enter the group in thE vpn cLIENT, the psk will be the password for the group..when the connection is successful you will get the username and password dialog where you key in your personal information.
Let us know if it works
10-25-2007 08:23 AM
10-25-2007 08:34 AM
This works for me...
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map outside_dyn_map 40 set transform-set ESP-3DES-SHA
crypto isakmp identity address
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
10-25-2007 09:04 AM
Thank you, that worked wonderfully.
Now my next question is how do I setup for certain clients to access only certain networks?
Again, thank you very much.
Seth
10-25-2007 09:12 AM
Will these users be part of the same tunnel group or will you create differnet tunnel groups for different classes of users?
10-25-2007 09:28 AM
I guess they can be part of the same group, just different user names and networks accessed.
Seth
10-25-2007 09:41 AM
This should help you some...
This will show you how to create a vpn-filter acl which can be applied to a tunnel group policy or individual user account.
The other option is to remove "sysopt connection permit-vpn". This will stop ipsec traffic from bypassing your interface acl's. Then you can simply write the access you desire in your outside access list.
10-25-2007 11:48 AM
Thank you again for the help. I did figure out that all I needed to do was add and ACL and then add a user and apply that ACL to the user.
Seth
