Community Member
VPN Issue - Sub-Interface Configuration
I have a PIX515 with 3 interfaces. I have configured the third interface as a sub-interface and assigned it a vlan. I am getting "No translation group found for udp src outside" error message with the source address coming from my VPN pool. Any ideas?
1 REPLY
Silver
Re: VPN Issue - Sub-Interface Configuration
This error message means: A packet does not match any of the outbound nat rules.
This message signals a configuration error. If dynamic NAT is desired for the source host,
ensure that the nat command matches the source IP
address. If static NAT is desired for the source host, ensure that the local IP address of the
static command matches. If no NAT is desired for the source
host, check the access-list bound to the nat 0 access-list.
228
