vpn lan-to-lan with pix behind router
jsastre 21 sep 17:31 mostrar opciones
De: "jsastre" <jssas...@hotmail.com> - Buscar mensajes de este autor
Fecha: Wed, 21 Sep 2005 08:31:05 -0700
Local: Mié 21 sep 2005 17:31
Asunto: pix behind router
Responder | Responder al autor | Reenviar | Imprimir | Mensaje individual | Mostrar mensaje original | Eliminar | Notificar abuso
I'm going trying connect 2 pix in a Lan-to-Lan vpn in the next
schema:
Lan1 -- Pix1 -- Router ------- Internet --------- Pix2 --- Lan2
The problem is that between Pix1 and Router there is a private lan
and although I have redirected all traffic get by Router to Pix1
(ipsec, ip 50, 51,... included), the vpn doesn't work. Any idea?
Thanks in advance,
J.
Config: Pix1 inside: 192.168.10.1/24
Pix1 outside: 192.168.2.2/24
Router inside: 192.168.2.1/24
Router outside: Public IP 1
Pix 2 outside: Public IP 2
Pix 2 inside: 192.168.20.1/24
Re: vpn lan-to-lan with pix behind router
Are you using PAT or static nat for PIX 1 on the router?
You may need to enter the command:
isakmp nat-traversal
on both pix's
this command wraps all ipsec packets in UDP and allows you to pass traffic through nat devices.
let me know if this works
Yes, I have just connectivity, anyway any in the router cut the icmp traffic but it's other issue.
Thanks a lot for your reply.
J.
I'm sorry, what was that?
105
