Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VPN load balancing not working correctly
I have two vpn3030s configured for load balancing. They appear to recognize one another as the correct vpn(priority 10) appears to be the master. The slave however keeps getting an error message i the log "LBSSF master peer[205.172.49.252] is not answering HELLO".
He appears to timeout the master and switch himself to master where he immediately sees the master and goes back to slave. I am not sure the address above is correct for the error message, 205.172.49.252 is the virtual IP shared by both concentrators. I would expect to see hellos sent and received between the two physical interfaces. Any ideas? I am getting a buffer error on the master as well so all this may be memory related. Not sure at this point.
Johnny
1 REPLY
Bronze
Re: VPN load balancing not working correctly
it may be due to IP conflict.
also check this bug-id:CSCds70213.
Try these links for more info:
http://www.cisco.com/warp/public/471/vpn3k-conn.html
http://www.cisco.com/warp/public/471/ld_bl_vpn3000_7602.html
106
