vpn - Local Ident showing outside interface vs. inside!
I'm trying to configure a VPN with a 1720 and an 806 both running NAT (non-overload). The current (grin) problem preventing the VPN from working is when I do a "show crypto ipsec sa" the "Remote Ident" is a private network address (which is correct), but my Local Ident is showing up as my public address (not the local address). Both routers exhibit this behavior.
What command has to do with what address shows up in the Local Ident? I've got the routers bypassing NAT for VPN traffic. I appreciate all the help!
1 REPLY
Re: vpn - Local Ident showing outside interface vs. inside!
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
224
