Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VPN over wireless
Are there different concerns with accessing our network over a wireless VPN connection than from a broadband connection?
Thanks, Judy.
1 REPLY
Re: VPN over wireless
Normally not, except for some mtu issue, with which normally you could adjust anyway on some VPN clients
it should work fine. Also, make sure you use the latest drivers for wireless NIC you are using. If you are talking about Wireless Lan, the Cisco VPN client to VPN concentrator with the Cisco Aironet cards and AP works fine. If you are talking about wireless network that some ISP offer and you would be
using it with a PDA or such, Certicom has partnered with Cisco for their Movian client to be able to connect via VPN to a VPN 3000 concentrator.
154
