12-03-2005 07:02 AM - edited 02-21-2020 02:08 PM
i would connect a tunnel vpn beetwen two site with pix and draytec but connection not work.
my pix config is attacch.
This my debug crypto isak... output:
Pix# Dec 03 15:43:45 [IKEv1]: IP = 11.11.11.11, Connection landed on tunnel_group 11.11.11.11
Dec 03 15:43:46 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, PHASE 1 COMPLETED
Dec 03 15:43:46 [IKEv1]: IP = 11.11.11.11, Keep-alive type for this connection: None
Dec 03 15:43:46 [IKEv1]: IP = 11.11.11.11, Keep-alives configured on but peer does not support keep-alives (type = None)
Dec 03 15:43:46 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, Received remote IP Proxy Subnet data in ID Payload: Address 192.168.1.0, Mask 255.255.255.0, Protocol 0, Port 0
Dec 03 15:43:46 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, Received local IP Proxy Subnet data in ID Payload: Address 192.168.149.1, Mask 255.255.255.0, Protocol 0, Port 0
Dec 03 15:43:46 [IKEv1]: QM IsRekeyed old sa not found by addr
Dec 03 15:43:46 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, IKE Remote Peer configured for SA: lantolan
Dec 03 15:43:46 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, IKE: requesting SPI!
Dec 03 15:43:49 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, Duplicate Phase 2 packet detected. Retransmitting last packet.
Dec 03 15:43:55 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, Duplicate Phase 2 packet detected. Retransmitting last packet.
Dec 03 15:43:58 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, Connection terminated for peer 11.11.11.11. Reason: Peer Terminate Remote Proxy N/A, Local Proxy N/A
Dec 03 15:43:58 [IKEv1]: Group = 11.11.11.11, IP = 11.11.11.11, Removing peer from correlator table failed, no match!
Thanks.
12-04-2005 09:20 AM
anyone can help me? Please
07-13-2006 01:51 AM
did you find a solution for that problem? I have the same problem with on of my VPN tunnels.
Peer
07-13-2006 07:38 AM
Disable keep alive, and ensure all SA's are matching exact value on both peers.
