VPN Pix-to-client and how to reach systems on other interfaces
Dear ALL,
I've implemented a VPN Pix-to-Client and it seems to running ok.
As you can see, client will get the same inside class address (192.168.100.x) so I can reach systems from everywhere.
My questions are:
1 if I assign addresses' pool different subnet, how can I still reach inside systems ?
2 if I have other systems on these interfaces such dmz1 (192.168.10.0) dmz2 (192.168.20.0) how can I reach those systems from the
same client vpn access?
Alberto Brivio
ip local pool vpnpool1 192.168.100.70-192.168.100.80
access-list 102 permit ip 192.168.100.0 255.255.255.0 192.168.100.0 255.255.255.0
nat (inside) 0 access-list 102
sysopt connection permit-ipsec
crypto ipsec transform-set trmset1 esp-des esp-md5-hmac
crypto dynamic-map map2 10 set transform-set trmset1
crypto map map1 10 ipsec-isakmp dynamic map2
crypto map map1 interface outside
isakmp enable outside
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
vpngroup test address-pool vpnpool1
vpngroup test split-tunnel 102
vpngroup test idle-time 1800
vpngroup test password ********
1 ACCEPTED SOLUTION
Re: VPN Pix-to-client and how to reach systems on other interfac
Usually it is better to use another IP Address Range. The PIX will know that the VPN Client is using that range and route it correctly whitch is not the case when you are using the same IP Range as the inside interface.
To access another interface use the NONAT (your ACL 102) access-list that disables NAT between the VPN Network and the the neworks that you want to connect.
Config Example:
access-list NONAT permit ip Internalnet ISubnetMask VPN-Pool 255.255.255.0
access-list NONAT permit ip DMZnet DMZSubnetMask VPN-Pool 255.255.255.0
nat (inside) 0 NONAT
aaa-server LOCAL protocol local
aaa authentication secure-http-client
crypto ipsec transform-set TRANS esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set TRANS
crypto map REMOTE 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map REMOTE client authentication LOCAL
crypto map REMOTE interface outside
isakmp nat-traversal 20
isakmp policy 10 encryption 3des
ip local pool VPNPool x.y.z.1-x.y.z.254
vpngroup VPNGroup address-pool VPNPool
vpngroup VPNGroup dns-server dns2 dns1
vpngroup VPNGroup default-domain localdomain
vpngroup VPNGroup idle-time 1800
vpngroup VPNGroup password grouppassword
username vpnclient password vpnclient-password
sincerely
Patrick
1 REPLY
Config Example:
sincerely
Patrick
89
