Vpn Pix to Pix connection problem
I have a Vpn Pix to Pix.
Pix A with internal network A and Pix B with internal network B
Communication through Vpn is ok and network host A be able communicate with network host B.
I have a third network C connected at network B through Cisco Router 1600.
Cisco Pix in network B have a route inside 192.168.3.0 255.255.255.0 192.168.2.1 (ip Cisco Router 1600 in betwork B).
Network A is 192.168.1.0
Network B is 192.168.2.0
Network C is 192.168.3.0
Network host A don't reach to communicate with network host C when host network B be able communicate with network host C.
My question is this :
What do I configure on the Pix to resolve the problem?
how do i configure the television to activate the communication between Network host A and network host C?
Many Thanks
Re: Vpn Pix to Pix connection problem
I'm assuming you want to communicate across the VPN here. In PIX-A you need to change your crypto and NAT 0 access-lists to be:
> access-list xxx permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
> access-list xxx permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
Make sure PIX-A has a route to the 192.168.3.0 network pointing out the outside interface (same as the route for 192.168.2.0). Then on PIX-B you need to update it's crypto and NAT 0 access-lists to be:
> access-list xxx permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
> access-list xxx permit ip 192.168.3.0 255.255.255.0 192.168.1.0 255.255.255.0
Can you please send me the pix -to -pix vpn configuration between Head office and multiple remote sites.
Many Thanx
Tahir Khan
Network Engineer
My configuration:
PixA
: Saved
PIX Version 6.1(3)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list acl_in permit icmp any any
access-list acl_in permit tcp any any
access-list acl_in permit udp any any
access-list acl_out permit icmp any any
access-list 100 permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list 110 permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
access-list 100 permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
access-list 110 permit ip 192.168.1.0 255.255.255.0 192.168.3.0 255.255.255.0
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x 255.255.255.248
ip address inside 192.168.1.254 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 x.x.x.x
nat (inside) 0 access-list 100
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group acl_out in interface outside
access-group acl_in in interface inside
route outside 0.0.0.0 0.0.0.0 81.72.205.30 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto map ToPixB ipsec-isakmp
crypto map ToPixB 10 match address 110
crypto map ToPixB 10 set peer x.x.x.x
crypto map ToPixB 10 set transform-set myset
crypto map ToPixB interface outside
isakmp enable outside
isakmp key ********** address x.x.x.x netmask 255.255.255.255
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 1000
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:ff629b12df4d0dc56077cb8b8c1577ad
PixB
: Saved
PIX Version 6.1(3)
names
access-list 100 permit ip 192.168.2.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 110 permit ip 192.168.2.0.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 100 permit ip 192.168.3.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list 110 permit ip 192.168.3.0.0 255.255.255.0 192.168.1.0 255.255.255.0
pager lines 24
mtu outside 1500
mtu inside 1500
ip address inside 192.168.2.254 255.255.255.0
pdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
route inside 192.168.3.0 255.255.255.0 192.168.2.1 1
http server enable
floodguard enable
crypto map ToPixA 10 ipsec-isakmp
crypto map ToPixA 10 match address 110
crypto map ToPixA 10 set peer x.x.x.x
crypto map ToPixA 10 set transform-set myset
crypto map ToPixA interface outside
isakmp key ******** address x.x.x.x netmask 255.255.255.255
telnet timeout 5
ssh timeout 5
terminal width 80
Cryptochecksum:a1c8f6e20b7d9dd80b5d724d567cf943
Many Thanks
Tahirk,
Other than pixA missing part of its config, probably just didnt make the paste:
should be
crypto map ToPixB 10 ipsec-isakmp
Configuration looks good. Did you clear the tunnels out? "clear crypto ipsec sa" and "clear crypto isakmp sa". How about clear xlate, wr mem and reload? Does the 192.168.2.1(im assuming this is a router and not a dual homed server) have a static route for the 192.168.1.0/24 pointed back to 192.168.2.254? Or a default route to 192.168.2.254? After testing "Both ways", post the output from your "show crypto ipsec sa" from both pix so we can see which side the problem is on.
Kurtis Durrett
101
