VPN (Problem pinging internal IP from VPN Client
I am running Client 3.6.3 on Windows 2000 pro. It seems to be connected but I can not ping any IP that is behind the PIX. There is only one windows 2000 pro pc in the internet network, and one windows 2000 pro in the outside network. Can anyone help me? I really can not see what is wrong with my configuration....Once client connects to PIX, I received a IP 192.168.2.10. I can see 216.170.1.2 as well. However, I also get an warning "Sev=Warning/3 IKE/0xA3000058 Received malformed message or negotiation no longer active (message id:0xD50CEC90)
Building configuration...
: Saved
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
access-list inside_outbound_nat0_acl permit ip 192.168.1.0 255.255.255.0 192.168.2.0 255.255.255.0
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside 216.170.1.2 255.255.255.0
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool icgpool 192.168.2.10-192.168.2.20
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 216.170.1.129 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
no sysopt route dnat
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-MD5
crypto map outside_map 20 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp identity address
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup icgvpn address-pool icgpool
vpngroup icgvpn idle-time 1800
vpngroup icgvpn password ********
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.1.5-192.168.1.133 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:063b3b1a5165f79269e763ff223ed88c
: end
[OK]
Re: VPN (Problem pinging internal IP from VPN Client
CAn't see anything wrong in the config. Does the internal host have a default route pointing to the PIX inside address?
If you double-click on the padlock icon after your tunnel is established, do you see a yellow key next to the 0.0.0.0 network after you try and ping, this indicates that the SA has been successfully built. Do you see the "packets encrypted" counter go up when you ping? Ifyou do a "sho cry ipsec sa" on the PIX, od you see te "Pkts Decaps" counter go up (this indicates the PIX has received those ping packets from your client and has decrypted them)? Do you also see the "Pkts Encaps" counter go up, this indicates the internal host has replied to the pings and sent them to the PIX, and the PIX has encrypted them and sent them back to your PC? Do you also then see the Packets Decrypted counter go up in the client, indicating it has seen the encrypted replies from the PIX?
Checking the 4 counters above and seeing which ones increment and which ones don't should give you a good indication of where the problem lies.
Was this issue resolved? I have a similar issue on Win XP. The Cisco Client V. 3.6.3 passes packets out but receives none. - But it had been working for months.
95
