VPN PROBLEM
Hy,
I ve got a problem on my VPN. I try to add a VPN Client access to another VPN and it won' t work.
I connect but I do not arrive to ressource.
Wine Bordeaux to anyone help me !
thx u
access-list NONAT permit ip 1.0.0.0 255.255.255.0 192.168.0.0 255.255.0.0
access-list NONAT permit ip 1.0.0.0 255.255.255.0 172.16.1.0 255.255.255.0
access-list NONAT permit ip 192.168.0.0 255.255.0.0 1.0.0.0 255.255.255.0
access-list NONAT permit ip 172.16.1.0 255.255.255.0 1.0.0.0 255.255.255.0
access-list GroupVPN_splitTunnelAcl permit ip 1.0.0.0 255.255.255.0 any
access-list outside_cryptomap_dyn_20 permit ip any 172.16.1.0 255.255.255.0
nat (inside) 0 access-list NONAT
sysopt connection permit-ipsec
crypto ipsec transform-set TRANS_ESP_DES_MD5 esp-des esp-md5-hmac
crypto ipsec transform-set TRANS_ESP_DES_MD5 mode transport
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set TRANS_ESP_DES_MD5
crypto map newmap 11 ipsec-isakmp
crypto map newmap 11 match address NONAT
crypto map newmap 11 set peer 205.0.0.1
crypto map newmap 11 set transform-set ESP-DES-MD5
crypto map newmap 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map newmap interface outside
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
isakmp enable outside
isakmp key ******** address 205.0.0.1 netmask 255.255.255.255
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp policy 11 authentication pre-share
isakmp policy 11 encryption des
isakmp policy 11 hash md5
isakmp policy 11 group 1
isakmp policy 11 lifetime 1000
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup GroupVPN address-pool pptp-pool
vpngroup GroupVPN split-tunnel GroupVPN_splitTunnelAcl
vpngroup GroupVPN idle-time 1800
vpngroup GroupVPN password ********
Re: VPN PROBLEM
These lines are your problem:
Now that you have defined an additional client crypto map, you need to separate your NONAT ACL from your LAN-to-LAN ACL. What's happening is your client is sending packets to an inside host (on the 1.0.0.0 net), but when the reply hits the PIX the PIX reads the crypto map from top-down, so it sees the "crypto map newmap 11" instance first for the LAN-to-LAN tunnel. It compares the NONAT ACL with the traffic, sees that it matches and sends the reply packet over the LAN-to-LAN tunnel, rather than back to your VPN client.
I'm assuming here that 1.0.0.0 is this PIX's inside network, 192.168.0.0 is the remote PIX's inside network, and 172.16.1.0 is the pptp-pool of VPN Client IP addresses. If I'm wrong with any of that substitute the correct values below.
First off, clean up your NONAT ACL by making it just this:
Then create a new ACL specifically for your LAN-to-LAN tunnel:
access-list L2L permit ip 1.0.0.0 255.255.255.0 192.168.0.0 255.255.0.0
Then set your LAN-to-LAN crypto map to look at this ACL rather than at your NONAT one:
crypto map newmap 11 match address L2L
That should get you going. Be careful when playing around with crypto map ACL's though, you can stop all traffic going through the PIX. Safest thing is to do the following:
no crypto map newmap interface outside
Also, when you remove ACL's in the PIX, be aware that this can remove other commands, so make sure everything is still there before re-applying the crypto map (for example, removing the NONAT access-list will automatically remove the "nat (inside) 0 access-list NONAT" command, so you need to add it back in after adding in the new NONAT ACL).
Re: VPN PROBLEM
Thk a lot !
If you take Holidays or if you work in France contact me for taking some of bottle of Bordeaux Wine !
ofulbert@ocea.net
94
