VPN Problems
I can vpn in just fine. The IP address that I pull is 192.168.1.200 so thats right. What is happening though is after I connect I lose all internet and I can't see anybody on my local lan or on the lan that I have vpn into. Our DNS server is also our DHCP server and our local lan is the same IP range that the VPN lan I am connecting to is. I don't know if that is the problem or not. After I connect I still can't see either network. Can you please help?
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside
security100
enable password xxx
encrypted
passwd xxxx
encrypted
hostname pixfirewall
domain-name
ciscopix.com
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inside_outbound_nat0_acl permit ip any 192.168.1.200 255.255.255.248
access-list outside_cryptomap_dyn_20 permit ip any 192.168.1.200 255.255.255.248
access-list outside_access_in permit icmp a
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute retry 4
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool CWS 192.168.1.200-192.168.1.205
pdm location 192.168.1.0
255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group outside_access_in in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup CWS address-pool CWS
vpngroup CWS dns-server 192.168.1.2 64.193.208.5
vpngroup CWS default-domain CWS
vpngroup CWS idle-time 1800
vpngroup CWS password ********
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
terminal width 80
Cryptochecksum:xxxx
Silver
Re: VPN Problems
You will need to do split-tunneling. It will permit only the VPN traffic over the tunnel.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a0080172787.html
Re: VPN Problems
Thats right you could use the split tunnel option which would allow you to browse the Internet on the same time as you are connected to your VPN.
Security Risk !
But This could result that you can get hijacked and someone could enter into your corporate network via your VPN Client.
config example Split tunnel:
access-list SplitTunnelACL permit ip vpnpool-net 255.255.255.0 any
vpngroup VPNGroup split-tunnel SplitTunnelACL
Another way might be by installing a Proxy server on your corporate network which would allow you to access the Internet. You just need to add the proxy in your browser.
OpenSource Proxy = Squid (Linux)
Symantec offers also a free proxy server if you use their corporate products.
sincerely
Patrick
Re: VPN Problems
still can't connect to server on local lan and cannot connect to internet while in vpn connection.
Here is what my config looks like now. I changed the subnet for other reasons but the config should look somewhat the same execpt for the entrys that you recommended.
PIX Version 6.3(5)
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
domain-name ciscopix.com
fixup protocol smtp 1025
names
access-list outside_access_in permit tcp any interface outside eq 3389
access-list outside_access_in permit icmp any any
access-list inside_outbound_nat0_acl permit ip any 10.168.1.192 255.255.255.224
access-list outside_cryptomap_dyn_20 permit ip any 10.168.1.192 255.255.255.224
access-list familyabuse_splitTunnelAcl permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address inside 10.168.1.1 255.255.255.0
ip local pool familyabuse 10.168.1.201-10.168.1.210
pdm location 10.168.1.200 255.255.255.255 inside
pdm history enable
arp timeout 14400
static (inside,outside) tcp interface 3389 10.168.1.200 3389 netmask 255.255.255
.255 0 0
http server enable
http 10.168.1.0 255.255.255.0 inside
floodguard enable
vpngroup familyabuse address-pool familyabuse
vpngroup familyabuse dns-server 10.168.1.200 64.193.208.5
vpngroup familyabuse wins-server 10.168.1.200
vpngroup familyabuse default-domain familyabusecenter.org
vpngroup familyabuse split-tunnel familyabuse_splitTunnelAcl
vpngroup familyabuse idle-time 1800
vpngroup familyabuse password ********
telnet 10.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 10.168.1.2-10.168.1.199 inside
dhcpd dns 10.168.1.200 64.193.208.5
dhcpd wins 10.168.1.200
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain familyabusecenter.org
dhcpd enable inside
terminal width 80
Cryptochecksum:f572adca6d4e4cb22017653ce428ba67
: end
Silver
Re: VPN Problems
This should specifically match traffic to your servers. Permit ip any any is as good as not having split tunneling ;-)
166
