Community Member
VPN problems
My vpn is saying that it is connected, but when I try to map a network drive or even try to go to the internet I can't. Also the only device that I can ping are is the subnet that was dynamiclly asigned via pix firewall. Everything on my local lan is blocked until I disconnect the vpn. This is the config of the PIX that I am trying to vpn into.
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx encrypted
passwd xxxx
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol smtp 1025
fixup protocol sqlnet 1521
fixup protocol tftp 69
access-list outside_access_in permit tcp any interface outside eq 3389
access-list outside_access_in permit icmp any any
access-list inside_outbound_nat0_acl permit ip any
access-list outside_cryptomap_dyn_20 permit ip any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute retry 4
ip address inside
ip audit info action alarm
ip audit attack action alarm
ip local pool familyabuse
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 1 0 0
static (inside,outside) tcp interface 3389 3389 netmask 255.255.255
.255 0 0
access-group outside_access_in in interface outside
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup familyabuse address-pool familyabuse
vpngroup familyabuse dns-server
vpngroup familyabuse wins-server
vpngroup familyabuse default-domain
vpngroup familyabuse idle-time 1800
vpngroup familyabuse password ********
telnet inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address inside
dhcpd dns
dhcpd wins
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd domain
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
: end
Community Member
Re: VPN problems
This is default behavior of VPN. When you connect from VPN client, you will be a part of the VPN server allocated LAN network. Later on there will be no significance of local IP, that’s why your share drive and internet not works.
To overcome this issue you can unable SPLIT TUNNELING concept on VPN server i.e.PIX., But its supported on PIX 7.X or VPN Concetrators.
Community Member
Re: VPN problems
I think you mean you have to define a split tunnel and this is a supported set of commands for version 6 as well.
These are the lines you would need to add (especially if you don't want to use over your outside_crypto ACL):
access-list Tunnel permit ip any
vpngroup familyabuse split-tunnel Tunnel
(I usually don't use an outside_crypto_dyn ACL but I believe the PDM likes this, if that is what you've used instead of CLI.)
Two last questions:
Why are you using any in your access-lists instead of defining the internal network?
Also, why don't you define an entirely different scheme for your vpn groups, e.g. so as not to cause confusion and be able to define the networks in the ACLs clearly?
Just some suggestions :-)
Good luck,
Re: VPN problems
I yust would like to confirm the Post of Nicole.
Yes split tunnel solvs the limitation.
Yes PIX OS 6.x supports Split tunnel.
But it would be a better security pratcise to use a Proxy Server for the VPN users to access the Internet when the users are connected to the VPN.
If a host (VPN client) gets hijacked on the Internet the Intruder will be able to enter into your corporate network. Which is not the case when you use a Proxy server.
Free proxys = Squid (Linux) or Symantec (With Enterprise Ed.)
