VPN proplem between Contivity and Pixfirewall 506E
The tunnel is up but I can not ping between 2 sites. I don't known why although I am using static routing
1 REPLY
Re: VPN proplem between Contivity and Pixfirewall 506E
If your tunnel is up and routing is looking good, we need to check the IPSec SA's to see whether there are any encrypts and decrypts and also make sure that you are bypassing NAT ( NAT 0 ) on the pix for the IPSec traffic, if the pix is configured for NAT.
Arul
87
