VPN remote acess - same username
Hi there,
I am newbie with firewall and vpn's.
I have an ASA 5510 configured for vpn remote access. Users establish vpn using cisco vpn client.
Authentication is local. Does anyone know if more than one person can use the same username?
Let's say user1 is connected and then someone else also connects using user1. Will the connection drop for the first user?
1 ACCEPTED SOLUTION
Re: VPN remote acess - same username
You can have the same username used multiple times - however I would not recommend this.
The default number is 3 times - you change this via:-
group-policy <> attributes
vpn-simultaneous-logins #
#= number of sim logins
HTH>
1 REPLY
HTH>
118
