01-05-2007 01:35 AM - edited 02-21-2020 02:47 PM
Hi All, I'm beginning to get a little frustrated setting the above up. I have 3 sites A,B & C. Site A is the hub and has VPN connections to both B and C, however I would like Site B to communicate to site C via site A. Please see attached, you will see what I have configured so far....
The VPN between site A and B is working and between A and C.... but not B & C!!!
01-05-2007 02:08 AM
You need to disable fast switching on the outside interface:
Router(config-if)# no ip route-cache
(when the router see a packet entering and then exiting the same interface, puts that in fast switching and doesn't process the packet).
See http://cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7ca.html for more details.
As well, on Sire A you can add statics for site B and C subnets pointing to the external interface of the router. This will prevent a fast switching behaviour.
If this helped, please rate.
Daniel
01-05-2007 02:38 AM
Hi Daniel,
Thanks for your reply, I have done as suggested and disabled fast switching, also added the 2 routes to SiteA router. Still no luck I'm afraid...
Thanks again for you help
01-05-2007 02:43 AM
Thinking about it, I dont know if this makes a difference, but I NONAT acces-lists.....
01-05-2007 02:49 AM
also getting an access denied message when packet debugging in SiteA
01-05-2007 04:30 AM
OK, if it is not a missconfiguration somewhere and this stil doesn't work, you can use GRE/IPSEC scenario. Since the traffic will be between two GRE interfaces and not back and forth on one interface, this should solve your problem.
Please rate if thie helped.
Daniel
