Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
VPN S/W Client Timeout Problem
I'm using a VPN 3020 and having problems with VPN client connections timing out after 10 minutes. No matter what value I set in Configuration | User Management | Groups | Test | Maximum Connect Time, the connection always terminates after 10 minutes with the following log messages;
23199 09/30/2005 09:57:22.730 SEV=5 IKE/50 RPT=40 <IP Address>
Group [Test] User [<user>]
Connection terminated for peer <user>.
Reason: IPSec SA Max time exceeded
Remote Proxy 10.13.254.1, Local Proxy 0.0.0.0
23202 09/30/2005 09:57:22.730 SEV=5 IKE/194 RPT=48 <IP Address>
Sending IKE Delete With Reason message: Maximum Configured Connection Time Exceeded.
I've tried inheriting the settings from the Base Group but the result is the same. The SA lifetime is 28800 seconds so I don't think that's the problem.
The VPN Concentrator version is 4.7.1 and the Cisco VPN Client version is 4.6.04.0043 on Windows 2000.
Any ideas as to what I might be doing wrong?
Colin
Gold
Re: VPN S/W Client Timeout Problem
have you try to set the idle timeout as well?
also try to set those values to 0, which means infinity.
Initially it was 0 but still it timeouts after 10 minutes.
I have also tried changing the Idle Timeout but that also makes no difference.
I've done some more testing and found that my problem disappears when I set Authentication (under Groups|Group_Name|IPSec) to "none" (it was "RADIUS" previously), and the max connect time behaves as advertised. I need to authenticate these remote users against a RADIUS server in addition to a pre-shared key so I can't leave it like this.
I can't see any RADIUS-related setting that would account for this. Any ideas?
Colin
143
