VPN site to site & VPN client on ASA 5520 on same outside
   hi, i am jonathan rivero.
i have an ASA 5520 Version 8.0(2), i configured the VPN site to site and works fine, in the other apliance i configured the VPN Client for remote users, and works fine, but i try to cofigure the 2 VPNs on ASA 5520 on the same outside interface and i have the line   "crypto map outside_map interface outside (for VPN client)", but when I configure  the "crypto map VPNL2L interface outside, it overwrites the command", and therefore I can only have one connection.
the show run.
ASA1(config)# sh run
: Saved
ASA Version 8.0(2)
hostname ASA1
enable password 7esAUjZmKQSFDCZX encrypted
names
interface Ethernet0/0
nameif inside
security-level 100
ip address 172.16.3.2 255.255.255.0
interface Ethernet0/1
nameif outside
security-level 0
ip address 200.20.20.1 255.255.255.0
interface Ethernet0/1.1
vlan 1
nameif outside1
security-level 0
no ip address
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/4
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/5
shutdown
no nameif
no security-level
no ip address
passwd 2KFQnbNIdI.2KYOU encrypted
ftp mode passive
object-group network net-local
network-object 172.16.0.0 255.255.255.0
network-object 172.16.1.0 255.255.255.0
network-object 172.16.2.0 255.255.255.0
network-object 172.16.3.0 255.255.255.0
object-group network net-remote
network-object 172.16.100.0 255.255.255.0
network-object 172.16.101.0 255.255.255.0
network-object 172.16.102.0 255.255.255.0
network-object 172.16.103.0 255.255.255.0
object-group network net-poolvpn
network-object 192.168.11.0 255.255.255.0
access-list nat-outside extended permit ip object-group net-local any
access-list nonat extended permit ip object-group net-local object-group net-remote
access-list nonat extended permit ip object-group net-local object-group net-poolvpn
access-list splittun-vpngroup1 extended permit ip object-group net-local object-group net-poolvpn
pager lines 24
mtu inside 1500
mtu outside 1500
mtu outside1 1500
ip local pool ippool 192.168.11.1-192.168.11.100 mask 255.255.255.0
no failover
icmp unreachable rate-limit 100 burst-size 10
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 access-list nat-outside
route outside 0.0.0.0 0.0.0.0 200.20.20.1 1
route inside 172.16.0.0 255.255.255.0 172.16.3.2 1
route inside 172.16.1.0 255.255.255.0 172.16.3.2 1
route inside 172.16.2.0 255.255.255.0 172.16.3.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 86400
crypto ipsec security-association lifetime kilobytes 400000
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-SHA
crypto map VPNL2L 1 match address nonat
crypto map VPNL2L 1 set peer 200.30.30.1
crypto map VPNL2L 1 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption aes-256
hash sha
group 2
lifetime 86400
crypto isakmp policy 65535
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics access-list
group-policy vpngroup1 internal
group-policy vpngroup1 attributes
banner value ++++Welcome to Cisco Systems 7.0.+++++
dns-server value 192.168.0.1 192.168.1.1
split-tunnel-policy tunnelspecified
split-tunnel-network-list value splittun-vpngroup1
default-domain value ad-domain.local
split-dns value ad-domain.local
address-pools value ippool
username asa1 password VRTlLlJ48/PoDKjS encrypted privilege 15
tunnel-group 200.30.30.1 type ipsec-l2l
tunnel-group 200.30.30.1 ipsec-attributes
pre-shared-key *
tunnel-group vpngroup1 type remote-access
tunnel-group vpngroup1 general-attributes
address-pool ippool
default-group-policy vpngroup1
tunnel-group vpngroup1 ipsec-attributes
pre-shared-key *
prompt hostname context
Cryptochecksum:00000000000000000000000000000000
: end
ASA2(config)#sh run
encryption 3des
hash md5
group 2
lifetime 86400
pre-shared-key cisco
my topology:
i try with the next links but didn`t work
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080912cfd.shtml
http://www.cisco.com/en/US/products/ps6120/products_tech_note09186a00807e0aca.shtml
Best Regards...
1 ACCEPTED SOLUTION
"I thing so of the force the ASA with the new route outside, why this? "
without the route ASA pushes traffic to inside, by default.
Anyway, this must have been a learning experience.
I hope, this has been any help.
Please rate, all helful post.
thanks
Rizwan Rafeek.
VIP Purple
As you have seen, there can only be one crypto-map at the interface. So everything has to go into one crypto-map which can be achieved with the help of the sequence-numbers (the "1" above).
What you need is:
crypto map YOUR-CRYPTO-MAP-NAME 1 match address nonat
crypto map YOUR-CRYPTO-MAP-NAME 1 set peer 200.30.30.1
crypto map YOUR-CRYPTO-MAP-NAME 1 set transform-set ESP-3DES-MD5
crypto map YOUR-CRYPTO-MAP-NAME 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map YOUR-CRYPTO-MAP-NAME interface outside
Just make sure that the dynamic entries always have a higher seq-# than the site-2-site sequence-numbers.
HTH, Karsten
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
Re: VPN site to site & VPN client on ASA 5520 on same outside
Hi Jonathan,
I am trying to understand, what is that you are trying to achieve, as your description is not clear.
You have remote-vpn client login into one of your ASA and you want remote vpn-client to be able to access both site-to-site remote networks, is this right?
thanks
Hi riz....let me explained.
I have 2 VPN (remote and site to site), the VPN remote is successful or UP, the VPN site to site is down, the 2 VPN is configured on same ASA (TresASA1) and the same outside.
I try configure VPN site to site with ASDM and CLI but unsuccessful. the configuration current is posted.
thk for help me!!!
Please post your most current config as an attachement.
thanks
Is this configuration running on real hardware or you are trying this out of some software based simulators?
this real appliance ASA5520, and this is my current configuration.
TresASA1(config)# sh run
: Saved
ASA Version 8.2(5)
hostname TresASA1
enable password E0HXgOXKEFi9sKqd encrypted
names
interface GigabitEthernet0/0
nameif inside
security-level 100
interface GigabitEthernet0/1
nameif outside
security-level 0
interface GigabitEthernet0/2
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa825-k8.bin
ftp mode passive
network-object 172.16.4.0 255.255.255.0
network-object 172.16.5.0 255.255.255.0
network-object 172.16.6.0 255.255.255.0
network-object 172.16.7.0 255.255.255.0
network-object 172.16.8.0 255.255.255.0
network-object 172.16.9.0 255.255.255.0
network-object 172.16.11.0 255.255.255.0
access-list nat extended permit ip object-group net-local any
access-list nonat1 extended permit ip object-group net-local object-group net-remote
pager lines 24
logging console debugging
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 200.20.20.2 1
route inside 172.16.1.0 255.255.255.0 172.16.3.1 1
route inside 172.16.2.0 255.255.255.0 172.16.3.1 1
route inside 172.16.4.0 255.255.255.0 172.16.3.1 1
route inside 172.16.5.0 255.255.255.0 172.16.3.1 1
route inside 172.16.6.0 255.255.255.0 172.16.3.1 1
route inside 172.16.7.0 255.255.255.0 172.16.3.1 1
route inside 172.16.8.0 255.255.255.0 172.16.3.1 1
route inside 172.16.9.0 255.255.255.0 172.16.3.1 1
route inside 172.16.10.0 255.255.255.0 172.16.3.1 1
route inside 172.16.11.0 255.255.255.0 172.16.3.1 1
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
aaa authentication telnet console LOCAL
aaa authentication http console LOCAL
aaa authentication enable console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
crypto dynamic-map dyn_map 20 set transform-set ESP-3DES-SHA
crypto dynamic-map dyn_map 65535 set transform-set ESP-3DES-SHA
crypto map vpns 1 match address nonat1
crypto map vpns 1 set peer 200.30.30.1
crypto map vpns 1 set transform-set ESP-3DES-MD5
crypto map vpns 65535 ipsec-isakmp dynamic dyn_map
crypto map vpns interface outside
crypto isakmp policy 1
encryption 3des
hash md5
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
vpn-sessiondb max-session-limit 450
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
no threat-detection statistics tcp-intercept
webvpn
anyconnect-essentials
banner value ++++Welcome to Cisco Systems.+++++ PROPIEDAD PRIVADA, CUALQUIER PERSONA AJENA AL CORPORATIVO, SERA CONSIGNADA A LAS AUTORIDADES
dns-server value 200.57.64.85 200.57.64.86
vpn-simultaneous-logins 20
username ho1a password DXK.iozVseM0AOzr encrypted privilege 15
username ciscouser password z4c9KJvMNAA7soAj encrypted privilege 15
username cisco password 3USUcOPFUiMCO4Jk encrypted privilege 15
pre-shared-key *****
address-pool ippool
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
no call-home reporting anonymous
Cryptochecksum:fea2b3d94bac70f546123d723bb6f06a
: end
TresASA1(config)#
TresASA2(config)# sh run
isakmp policy 20 is superceded by identical policy 1
: Saved
ASA Version 8.2(5)
hostname TresASA2
names
nameif inside
security-level 100
ip address 172.16.103.2 255.255.255.0
nameif outside
security-level 0
ip address 200.30.30.1 255.255.255.0
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
mtu management 1500
no failover
arp timeout 14400
route inside 172.16.100.0 255.255.255.0 172.16.103.2 1
route inside 172.16.101.0 255.255.255.0 172.16.103.2 1
route inside 172.16.102.0 255.255.255.0 172.16.103.2 1
route inside 172.16.103.0 255.255.255.0 172.16.103.2 1
http server enable
crypto map vpns 1 set peer 200.20.20.1
encryption 3des
hash md5
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 172.16.103.3-172.16.103.254 inside
dhcpd enable inside
webvpn
tunnel-group 200.20.20.1 type ipsec-l2l
tunnel-group 200.20.20.1 ipsec-attributes
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:9eb55d1b2d70db50cd19d7c07b7afe0b
: end
TresASA2(config)#
regards!!!
On device TresASA2
nameif outside
security-level 0
default route is: "route outside 0.0.0.0 0.0.0.0 200.20.20.1 1"
"VPN site to site is down, the 2 VPN is configured on same ASA (TresASA1) and the same outside."
your default gateway on device: TresASA2 and outside interface are not on the same subnet, not routable and so there is no wonder you cannot establish site-to-site vpn tunnel.
thanks
yes, I see my error, but the tunnel is down jet...
TresASA2(config)#
TresASA2(config)# sh route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is 200.30.30.1 to network 0.0.0.0
S    172.16.100.0 255.255.255.0 [1/0] via 172.16.103.2, inside
S    172.16.101.0 255.255.255.0 [1/0] via 172.16.103.2, inside
S    172.16.102.0 255.255.255.0 [1/0] via 172.16.103.2, inside
C    172.16.103.0 255.255.255.0 is directly connected, inside
C    200.30.30.0 255.255.255.0 is directly connected, outside
S*   0.0.0.0 0.0.0.0 [1/0] via 200.30.30.1, outside
TresASA2(config)#
TresASA1(config)#
TresASA1(config)# ping 200.30.30.1
Sending 5, 100-byte ICMP Echos to 200.30.30.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
TresASA1(config)# ping 172.16.103.1
Sending 5, 100-byte ICMP Echos to 172.16.103.1, timeout is 2 seconds:
Success rate is 0 percent (0/5)
TresASA1(config)# sh cry
TresASA1(config)# sh crypto isa
TresASA1(config)# sh crypto isakmp sa
There are no isakmp sas
TresASA1(config)# sh crypto  ipse
TresASA1(config)# sh crypto  ipsec sa
There are no ipsec sas
TresASA1(config)#
Hi there,
Please apply hightlighted "inspect icmp" on the global_policy from both firewall and then ping outside both IP address from each FW.
   inspect icmp
Please post the output from the below command from device: TresASA2.
show run | in route
Is default route "0.0.0.0 0.0.0.0" is being pushed to outside interface itself on TresASA2, rather than to default gateway?
Please update.
thanks
ok I changue the route on TresASA2, add the inpect ICMP in both ASA5520 and send the ping to both ASAs.
thk for you help....
If you are able to ping both outside interfaces, then initiate the traffice from one end to other from interesting network ip address to other side and see if tunnels come up.
update please
thanks
no, the tunnel is down.
you thing so of the trouble is the version, I can try with asa844-k8 version but I don't know configure NAT and VPN site to site  on this version. Between try with enable the debug crypto isa and debug crypto ipsec but no show me information.
"I can try with asa844-k8 version"
Version 8.44 is more complex nat and no-nats, so stick with your version for now.
Please add this static route on ASA2
route outside 172.16.0.0 255.255.0.0 200.30.30.2
Please add this static route on ASA1, as well.
route outside 172.16.0.0 255.255.0.0 200.20.20.2
When you initiate the tunnel, you must initiate the tunnel from source network address, you cannot initiate the tunnel from firewall itself, it won't work.
please update.
thanks
VIP Purple
Your testing is wrong. With that ping the tunnel is not triggered as the ping is sent from the outside IP of the ASA. But that source-IP is not included in your encryption definition.
It's best to test from a PC in your local network to a PC in the remote network.
hi karsten/riswanr74
yes yesterday  I try from LAN to LAN, but now re-configure the 2 ASA (same configuration copy and paste) and now test the tunnel and both tunnel the TresASA1 is up (site to site and remote), but in TresASA2 don't pass traffic across the tunnel, input the show crypto ipsec sa command and view of the numbers (#pkts encaps:  #pkts encrypt: , #pkts digest: 99) mismatch....
the configuration the access-list is:
TresASA1(config)# sh run access-list
TresASA1(config)# sh run crypto
encryption 3des
hash md5
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
TresASA1(config)# sh run tunnel
address-pool ippool
TresASA1(config)# sh run nat
TresASA1(config)# sh run global
TresASA1(config)#
TresASA2(config)# sh run access-list
TresASA2(config)# sh run nat
TresASA2(config)# sh run cryt
TresASA2(config)# sh run cryptoi
TresASA2(config)# sh run cryptto
encryption 3des
hash md5
group 2
lifetime 86400
encryption aes-256
hash sha
group 2
lifetime 86400
encryption 3des
hash sha
group 2
lifetime 86400
TresASA2(config)# sh run globa
TresASA2(config)#
thk !!!
VIP Purple
So you have packets flowing from ASA2 to ASA1 but nothing comes back. Are there any relevant log-messages on ASA1 while testing?
While testing you could do a packet-capture on ASA1 to see if the test-packets come back to the ASA (in the following form not while peak-hours):
ASA# capture CAP1 interface inside real-time
ok this is the output:
TresASA1(config)# capture CAP1 interface inside real-time
Warning: using this option with a slow console connection may
         result in an excessive amount of non-displayed packets
         due to performance limitations.
Use ctrl-c to terminate real-time capture
   1: 16:50:50.959239 172.16.103.1 > 172.16.3.1: icmp: echo request
   2: 16:50:52.959316 172.16.103.1 > 172.16.3.1: icmp: echo request
   3: 16:50:54.959667 172.16.103.1 > 172.16.3.1: icmp: echo request
   4: 16:50:56.959972 172.16.103.1 > 172.16.3.1: icmp: echo request
   5: 16:50:58.959911 172.16.103.1 > 172.16.3.1: icmp: echo request
   6: 16:51:00.960323 172.16.103.1 > 172.16.3.1: icmp: echo request
   7: 16:51:02.960353 172.16.103.1 > 172.16.3.1: icmp: echo request
   8: 16:51:04.960613 172.16.103.1 > 172.16.3.1: icmp: echo request
   9: 16:51:06.960948 172.16.103.1 > 172.16.3.1: icmp: echo request
  10: 16:51:08.960994 172.16.103.1 > 172.16.3.1: icmp: echo request
  11: 16:51:10.961376 172.16.103.1 > 172.16.3.1: icmp: echo request
  12: 16:51:12.961421 172.16.103.1 > 172.16.3.1: icmp: echo request
  13: 16:51:14.961650 172.16.103.1 > 172.16.3.1: icmp: echo request
  14: 16:51:16.962001 172.16.103.1 > 172.16.3.1: icmp: echo request
  15: 16:51:18.962062 172.16.103.1 > 172.16.3.1: icmp: echo request
  16: 16:51:20.962413 172.16.103.1 > 172.16.3.1: icmp: echo request
  17: 16:51:22.962505 172.16.103.1 > 172.16.3.1: icmp: echo request
  18: 16:51:24.962734 172.16.103.1 > 172.16.3.1: icmp: echo request
  19: 16:51:26.963054 172.16.103.1 > 172.16.3.1: icmp: echo request
  20: 16:51:28.963115 172.16.103.1 > 172.16.3.1: icmp: echo request
  21: 16:51:30.963527 172.16.103.1 > 172.16.3.1: icmp: echo request
  22: 16:51:32.963527 172.16.103.1 > 172.16.3.1: icmp: echo request
  23: 16:51:34.963756 172.16.103.1 > 172.16.3.1: icmp: echo request
  24: 16:51:36.964122 172.16.103.1 > 172.16.3.1: icmp: echo request
  25: 16:51:38.964183 172.16.103.1 > 172.16.3.1: icmp: echo request
  26: 16:51:40.964564 172.16.103.1 > 172.16.3.1: icmp: echo request
  27: 16:51:42.964610 172.16.103.1 > 172.16.3.1: icmp: echo request
  28: 16:51:44.964809 172.16.103.1 > 172.16.3.1: icmp: echo request
  29: 16:51:46.965190 172.16.103.1 > 172.16.3.1: icmp: echo request
  30: 16:51:48.965221 172.16.103.1 > 172.16.3.1: icmp: echo request
  31: 16:51:50.965602 172.16.103.1 > 172.16.3.1: icmp: echo request
  32: 16:51:52.965678 172.16.103.1 > 172.16.3.1: icmp: echo request
  33: 16:51:54.965892 172.16.103.1 > 172.16.3.1: icmp: echo request
  34: 16:51:56.966273 172.16.103.1 > 172.16.3.1: icmp: echo request
  35: 16:51:58.966273 172.16.103.1 > 172.16.3.1: icmp: echo request
  36: 16:52:00.966640 172.16.103.1 > 172.16.3.1: icmp: echo request
  37: 16:52:02.966716 172.16.103.1 > 172.16.3.1: icmp: echo request
  38: 16:52:04.966929 172.16.103.1 > 172.16.3.1: icmp: echo request
  39: 16:52:06.967326 172.16.103.1 > 172.16.3.1: icmp: echo request
  40: 16:52:08.967357 172.16.103.1 > 172.16.3.1: icmp: echo request
  41: 16:52:10.967723 172.16.103.1 > 172.16.3.1: icmp: echo request
  42: 16:52:12.967784 172.16.103.1 > 172.16.3.1: icmp: echo request
  43: 16:52:14.967982 172.16.103.1 > 172.16.3.1: icmp: echo request
  44: 16:52:16.968348 172.16.103.1 > 172.16.3.1: icmp: echo request
  45: 16:52:18.968410 172.16.103.1 > 172.16.3.1: icmp: echo request
  46: 16:52:20.968776 172.16.103.1 > 172.16.3.1: icmp: echo request
  47: 16:52:22.968852 172.16.103.1 > 172.16.3.1: icmp: echo request
  48: 16:52:24.969111 172.16.103.1 > 172.16.3.1: icmp: echo request
  49: 16:52:26.969432 172.16.103.1 > 172.16.3.1: icmp: echo request
  50: 16:52:28.969462 172.16.103.1 > 172.16.3.1: icmp: echo request
  51: 16:52:30.969874 172.16.103.1 > 172.16.3.1: icmp: echo request
  52: 16:52:32.969951 172.16.103.1 > 172.16.3.1: icmp: echo request
  53: 16:52:34.970118 172.16.103.1 > 172.16.3.1: icmp: echo request
  54: 16:52:36.970469 172.16.103.1 > 172.16.3.1: icmp: echo request
  55: 16:52:38.970546 172.16.103.1 > 172.16.3.1: icmp: echo request
  56: 16:52:40.970912 172.16.103.1 > 172.16.3.1: icmp: echo request
  57: 16:52:42.970973 172.16.103.1 > 172.16.3.1: icmp: echo request
  58: 16:52:44.971171 172.16.103.1 > 172.16.3.1: icmp: echo request
  59: 16:52:46.971522 172.16.103.1 > 172.16.3.1: icmp: echo request
  60: 16:52:48.971583 172.16.103.1 > 172.16.3.1: icmp: echo request
  61: 16:52:50.971949 172.16.103.1 > 172.16.3.1: icmp: echo request
  62: 16:52:52.972117 172.16.103.1 > 172.16.3.1: icmp: echo request
  63: 16:52:54.972239 172.16.103.1 > 172.16.3.1: icmp: echo request
  64: 16:52:56.972651 172.16.103.1 > 172.16.3.1: icmp: echo request
  65: 16:52:57.772939 arp who-has 172.16.3.4 tell 172.16.3.8
  66: 16:52:58.972651 172.16.103.1 > 172.16.3.1: icmp: echo request
  67: 16:53:00.973017 172.16.103.1 > 172.16.3.1: icmp: echo request
  68: 16:53:02.973109 172.16.103.1 > 172.16.3.1: icmp: echo request
  69: 16:53:04.973292 172.16.103.1 > 172.16.3.1: icmp: echo request
  70: 16:53:07.001678 172.16.103.1 > 172.16.3.1: icmp: echo request
  71: 16:53:09.001754 172.16.103.1 > 172.16.3.1: icmp: echo request
  72: 16:53:11.002197 172.16.103.1 > 172.16.3.1: icmp: echo request
  73: 16:53:13.002197 172.16.103.1 > 172.16.3.1: icmp: echo request
  74: 16:53:15.002456 172.16.103.1 > 172.16.3.1: icmp: echo request
  75: 16:53:17.002761 172.16.103.1 > 172.16.3.1: icmp: echo request
  76: 16:53:19.002822 172.16.103.1 > 172.16.3.1: icmp: echo request
  77: 16:53:21.003173 172.16.103.1 > 172.16.3.1: icmp: echo request
  78: 16:53:23.003372 172.16.103.1 > 172.16.3.1: icmp: echo request
  79: 16:53:25.003494 172.16.103.1 > 172.16.3.1: icmp: echo request
  80: 16:53:27.003829 172.16.103.1 > 172.16.3.1: icmp: echo request
  81: 16:53:29.003890 172.16.103.1 > 172.16.3.1: icmp: echo request
  82: 16:53:31.004424 172.16.103.1 > 172.16.3.1: icmp: echo request
  83: 16:53:33.004333 172.16.103.1 > 172.16.3.1: icmp: echo request
  84: 16:53:35.004592 172.16.103.1 > 172.16.3.1: icmp: echo request
  85: 16:53:37.004867 172.16.103.1 > 172.16.3.1: icmp: echo request
  86: 16:53:39.004913 172.16.103.1 > 172.16.3.1: icmp: echo request
  87: 16:54:19.243410 arp who-has 172.16.3.5 tell 172.16.3.4
  88: 16:57:58.513767 arp who-has 172.16.3.8 tell 172.16.3.4
  89: 16:58:11.834841 arp who-has 172.16.3.1 tell 172.16.3.5
89 packets shown.
0 packets not shown due to performance limitations.
TresASA1(config)#
let me tell you that I do ping from 172.16.103.1 to 172.16.3.1 the ping is unsuccessful, but I do ping from 172.16.3.1 to 172.16.103.1 the ping is successful.
CORE_Tres(config)#do sh ip interface br
Interface              IP-Address      OK? Method Status                Protocol
Vlan1                  unassigned      YES NVRAM  up                    up
Vlan2                  172.16.2.1      YES manual up                    up
Vlan4                  172.16.4.1      YES manual up                    up
Vlan5                  172.16.5.1      YES manual up                    up
Vlan7                  172.16.7.1      YES manual up                    up
Vlan8                  172.16.8.1      YES manual up                    up
Vlan9                  172.16.9.1      YES manual up                    up
Vlan10                 172.16.10.1     YES manual up                    up
Vlan11                 172.16.11.1     YES manual up                    up
Vlan99                 172.16.99.1     YES manual up                    up
Vlan101                unassigned      YES NVRAM  administratively down down
Vlan152                172.16.3.1      YES NVRAM  up                    up
Vlan153                unassigned      YES manual up                    up
FastEthernet2/0/1      unassigned      YES manual down                  down
FastEthernet2/0/2      unassigned      YES manual down                  down
FastEthernet2/0/3      unassigned      YES unset  down                  down
FastEthernet2/0/4      unassigned      YES unset  down                  down
FastEthernet2/0/5      unassigned      YES unset  up                    up
FastEthernet2/0/6      unassigned      YES unset  down                  down
FastEthernet2/0/7      unassigned      YES unset  down                  down
FastEthernet2/0/8      unassigned      YES unset  down                  down
FastEthernet2/0/9      unassigned      YES unset  up                    up
CORE_Tres(config)#do ping 172.16.103.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
CORE_Tres(config)#do telnet 172.16.103.1
Trying 172.16.103.1 ... Open
User Access Verification
Username: tresland
Password:
TresLAND#
so I think so that is the packet do not come back to TresASA2....
what do you think?
VIP Purple
could it be, that 172.16.3.1 is filtering the incoming ICMP-packets?
mmm, no, this is the access-list configure on TresASA1:
VIP Purple
not the ASA, the router that you try to ping.
Hi there,
Please make sure, your internal switch have a static-route in placed to push all remote-network segments (which are going over IPSec tunnel)  to its local firewall inside address.  This static must exists from both ends on internal switch.
thanks
yes...
TresASA2(config)# sh run object-group
TresASA2(config)# sh run route
route outside 0.0.0.0 0.0.0.0 200.30.30.2 1
TresASA2(config)# ping 172.16.100.1
Sending 5, 100-byte ICMP Echos to 172.16.100.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/10 ms
TresASA2(config)# ping 172.16.101.1
Sending 5, 100-byte ICMP Echos to 172.16.101.1, timeout is 2 seconds:
TresASA2(config)# ping 172.16.103.1
TresASA2(config)# ping 172.16.102.1
Sending 5, 100-byte ICMP Echos to 172.16.102.1, timeout is 2 seconds:
TresASA2(config)#
TresASA2(config)#
TresASA2(config)#
TresLAND(config-if)#exit
TresLAND(config)#
TresLAND(config)#
TresLAND(config)#do sh run | inc ip route
ip route 0.0.0.0 0.0.0.0 172.16.103.2
TresLAND(config)#ping 172.16.103.1
% Invalid input detected at '^' marker.
TresLAND(config)#do ping 172.16.103.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
TresLAND(config)#
TresASA1(config)# sh run object-group
TresASA1(config)# sh run route
TresASA1(config)# ping 172.16.3.1
Sending 5, 100-byte ICMP Echos to 172.16.3.1, timeout is 2 seconds:
TresASA1(config)# ping 172.16.11.1
Sending 5, 100-byte ICMP Echos to 172.16.11.1, timeout is 2 seconds:
TresASA1(config)#
CORE_Tres>
CORE_Tres>
CORE_Tres>en
Password:
CORE_Tres#sh run | inc ip route
ip route 0.0.0.0 0.0.0.0 172.16.3.2
CORE_Tres#sh ip interface br
CORE_Tres#
Please post your current config from both firewall as an attachedment, please as an attachement.
thanks
ok, the configuration is attached in notepad
Can you please add this static route on both devices.
Please remove this line from ASA2.
Please update.
thanks
hi rizwanr74
After the create the route the VPN site to site is successful ping (LAN to LAN) and the same time is successful VPN remote.
TresLAND#sh ip interface br
GigabitEthernet0/0         unassigned      YES unset  administratively down down
GigabitEthernet0/1         172.16.103.1    YES manual up                    up
Serial0/2/0                unassigned      YES unset  administratively down down
Serial0/2/1                unassigned      YES unset  administratively down down
Loopback0                  172.16.100.1    YES manual up                    up
Loopback1                  172.16.101.1    YES manual up                    up
Loopback2                  172.16.102.1    YES manual up                    up
Loopback4                  unassigned      YES unset  up                    up
TresLAND#ping 172.16.3.1
CORE_Tres#
CORE_Tres#ping 172.16.103.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/9 ms
CORE_Tres#
now the most complicated is the explication... I thing so of the force the ASA with the new route outside, why this? if I have the route outside default (route 0.0.0.0 0.0.0.0 ).
thanks
Rizwan Rafeek.
I understand, I try with GNS3 in version 8.0.2 and I dont had trouble, but as you tell me "experience".
thk for all and this is my MSN a24042004@hotmail.com
1732
