VPN through LAN side of 2610
Has anyone been able to create an outbound VPN from the LAN side of a 2610 running C2600 Software (C2600-JO3S56I-M), Version 12.1(27a)?
1 REPLY
Bronze
Re: VPN through LAN side of 2610
VPN Pass-through is a feature which allows a client to establish a tunnel only with a specific VPN server. So, if you need to securely access the configured VPN server as well as another VPN server or the Internet, this is not possible with VPN Pass-through enabled on the controller. Under such requirements, you need to disable VPN Pass-through. However, the WLC can be configured to act as passthrough in order to reach multiple VPN gateways when an appropriate ACL is created and applied to the corresponding WLAN. So, under such scenarios where you want to reach multiple VPN gateways for redundancy, disable VPN passthrough and create an ACL that allows access to the VPN gateways and apply the ACL to the WLAN.
100
