vpn thru wireless
is it possible to do an ipsec site to site vpn on routers tha is linked thru wireless?
thanks
1 ACCEPTED SOLUTION
Re: vpn thru wireless
Celso,
If both the routers are
a. able to communicate between each other
b. there isn't much lag,
c. and there isn't anything on the wireless devices that would block UDP 500 and ESP packets,
then you should not have a problem with the Site to Site tunnel establishment.
Hope this answers your query.
Rate this post, if it helps.
Cheers
Gilbert
1 REPLY
Celso,
Cheers
Gilbert
106
