06-17-2008 03:51 AM - edited 02-21-2020 03:46 PM
I've got many small sites with Linksys RV042 VPN routers which are doing IPSec VPN back to our main site 1812 router. These VPN tunnels all work great except that I've had to create RTR probes pinging the inside interface of each RV042 to keep the tunnels alive. If any of the RV042 internet feeds drop, the tunnels will not re-establish without manually clearing the crypto on the 1800 router (clear crypto sa) and then they come back up just fine. Has anyone else seen an issue with these RV042 routers? THanks.
06-23-2008 07:12 AM
could you provide the details of the debugs from the cisco router :
you should enter to global configuration mode and collect the debugs:
router>enable
router#debug crypto ipsec
router#debug crypto isakmp
router#clear crypto sa
router#clear crypto isa
router#ping [remote router inside] source [local router inside] than collect the debugs
06-23-2008 07:17 AM
I've tried to debug the vpn processes, but this router terminates a number of VPN tunnels, so the debug msgs would be hard to follow, and plus, we dont know when the tunnel would drop...sometimes it stays up for days, other times, it is up and down multiple times in a day. THanks for the help.
Jason
