VPN v5.0 install problem
When installing the VPN client, whether using the .exe or the .msi it proceeds to the pooint where it is installing the Cisco Virtual Adapter. It then stops and throws the error 1722. Once acknowleged, it rolls back the installation. This has happened on two different laptops. Have not had any reported issues on desktops.
I have been looking for a solution for the past couple of days and found nothing helpful. Has anyone else encountered this problem? and have a solution?
Silver
Re: VPN v5.0 install problem
Follow the procedure in the following document to manually uninstall and then reinstall the VPN client:
http://www.cisco.com/warp/public/471/vpn3K_uninstall.html
Thanks for the response. I have tried that solutiona and several others which refer to the same entries inthe registry. Problem remains.
Open a case with Cosco and they are working on it now.
372
