Community Member
VPN3000 : l2tp/IPSec without using Base Group
is it possible using a VPN3000 to enable l2tp over IPSec for a particular group while only IPsec is selected on the Base Group ?
1 REPLY
Silver
Re: VPN3000 : l2tp/IPSec without using Base Group
you can only use the configuration with the base group because you cannot configure the VPN Concentrator for a LAN-to-LAN tunnel in this scenario because the address is assigned dynamically to the remote device and is not always the same
95
