VPN3000 & remote access tunnel problem
If the IP network segment of remote access VPN client conflicted with VPN3000`s private interface IP network segment, can I still let the remote access VPN client to access the servers at VPN3000`s private network?
Best Regards,
Jackson Ku
1 REPLY
Re: VPN3000 & remote access tunnel problem
If you mean that say, the VPN client is on a network of 10.1.1.0/24, and you're also trying to connect to a network over the VPN of 10.1.1.0/24, then no, this won't work.
Theoretically it should if you're not doing split tunnelling, but the underlying Windows OS will grab the packet and send it straight out the LAN interface unencrypted, cause it thinks that you're trying to get to a local machine.
106
