VPN3000 Static NAT LAN-to-LAN rules
I cannot get a Static NAT LAN-to-LAN rules to work. I am running Version 4.1.1.Rel Feb 12 2004 17:54:39 on 3015 VPN Concentrator.
I have an IPSec LAN-to-Lan tunnel up. The Local Network is 10.100.40.0/24. I have a Static NAT LAN-to-LAN rule that translate a single host from 10.100.40.11 to 172.29.7.40 when it is talking to 172.29.1.0/24 on the other side of the tunnel. The NAT translation just does not happen.
In testing the IPSec tunnel, if I change the Local Network List to a single device 172.29.7.20 with a wild card of 0.0.0.0 then it works great. I can ping between a single device in my side 172.29.7.40 to the other side of the tunnel’s subnet 172.29.1.x/24 However, the NAT LAN-to-LAN rules would be meaningless in that configuration.
How can I get Static NAT LAN-to-LAN rules to work. I have done the obvious check by making sure that under “Configuration/Traffic Management/NAT/LAN-to-LAN Rules” that “LAN-to-LAN Tunnel NAT Rule Enabled” checkbox is checked. What else is there to check?
I have attached two screen shots of IPSec LAN-to-LAN and NAT LAN-to-LAN rules for reference. Please comment. Thank you.
Re: VPN3000 Static NAT LAN-to-LAN rules
Everything looks fine...any update on this?
Everything is fine and working. It turns out that the other side has configured a wrong subnet mask.
401
