VPN3000 - VPN3002 Hub and Spoke
Dear All,
Does it possible for the following scenario ?
Branch1---VPN3002 ---Internet---VPN3060---Internet---VPN3002---Branch2
Requirement 1: VPN3002 at Branch1 creates a tunnel to VPN3060
Requirement 2: VPN3002 at Branch2 creates a tunnel to VPN3060
Requirement 3: VPN3002 at Branch 1 connects to Branch 2 through VPN3060
Requirement 1 & 2 is possible but how is the possibility of requirement 3 ?
Appreciate for any help
Re: VPN3000 - VPN3002 Hub and Spoke
You should be able to define the Network list on the 3060 to be sent down to the Branch 1 3002, which will include the Network for the Branch 2 aswell.
So in this way Branch 1 will send the information through the tunnel to the Corporate for Branch 2 aswell, and do the vice versa for the Split tunnel list for Branch 2 group.
Hope this helps,
Aamir
Thanks Aamir,
Base on your suggestion, please kindly assist for the following questions:
1. Does VPN3060 re-route the packet with a destination address to Branch2 from Branch 1? How VPN3000 recognizes that the packet is not belongs to the network it is responsible for ?
2. If the VPN3000 learns the routes from both of branches through RRI (VPN3002 with Network Extension Mode) , does it still need to define the network list to be sent to both branches ?
3. Another option other than using VPN3002 at branches is using PIX (501 or 506). Does hub&spoke solution also possible with PIX at spoke and VPN3000 at hub , connection between spokes are through hub.
Really appreciate for your help.
Best Regards,
Engel
94
