07-17-2003 08:12 AM - edited 02-20-2020 10:51 PM
I have read conflicting documents on CCO regarding whether or not you can use network extension in a VPN3002 when connecting to PIX. Does this configuration work? Is it version dependent?
Thank you,
Eliot
Solved! Go to Solution.
07-17-2003 03:52 PM
Yes it works. The very first version had a few issues, but it's worked for quite a while now.
07-17-2003 03:52 PM
07-28-2003 01:06 PM
Thanks! It now looks that it may be a while before I need to do this but now I at least know that it works.
