vpn3005 to router vpn hub-and-spoke problem
knudsen-s
Dear all.
I have a question and hope there is some who can answer this problem.
I have a VPN 3005 in a hub and spoke, where the vpn3005 is the hub. I have 4 sites that are conecting to the vpn 3005, that is working fine, but i can not comunicate between the spokes. I can comunicate with the central site from all but not between the spokes..
any andee ??
I have tryed to use the reverse route injection and network lists, but no go.
best regards
Soren Knudsen
skn@qualitynet.dk
awaheed
I think we have a solution for you and its available on Cisco website at:
http://www.cisco.com/warp/public/471/vpn3k_lan2lan.html
Kindly configure your CVPN3000 accordingly and you should have what you want.
Thanks and Regards,
Aamir Waheed,
Cisco Systems, Inc.
CCIE#8933
HI
Thanx for the replay. I have done most of it but it it not working, the only thing i have not done is the follwing... can that be the problem...
I have defined 0.0.0.0 as the local net, and i am not using any routing protocol like ospf.
best regards
knudsen-s
HI....
Thanx for the answer, it worked... thnax
best regards
Soren Knudsn
