I'm trying to setup an IPSEC tunnel between a 3015 and 1600 router. The 1600 is configured with all the necessary commands and I can ping the two public address of each, yet the tunnel won't establish and I see no debug traces on the 1600 and nothing in the event log on the concentrator. The concentrator config should be ok, as when I hooked up a Vigor 2200 it "almost" setup the tunnel.
I have lifted the 1600 config from the : "Configuring L2L Tunnels on a VPN3000 conc with a Cisco IOS router".
Should I be able to do this, or will I have to use a 1700 series.
