VPN3030 - Using the 3 Ethernet Cards
The VPN3030 has 3 ethernet cards called, public/untrusted, dmz and private/trusted. I would like to confirm if I can use both public and DMZ to end VPN, IPSEC and PPTP Tunnels.
In other works public and DMZ interfaces have the same funcionality?
Thanks & Regards
Pedro
Bronze
Re: VPN3030 - Using the 3 Ethernet Cards
you can terminate VPN on both DMZ and Public, thas true, but you can't make TWO interfaces marked as Public at the same time, that basically leaves you using one interface (at a time) when you are trying IPSec NAT Transparency, though IPSec(ESP) connections work fine to any interface(doesn't requires it to be marked as public).
Thx
Afaq
Thanks. It will work! I am going to use one interface, DMZ, to finish PPTP or VPN tunels for local, no NAT, wireless lan access.
The public will be for Internet access VPNs.
Thanks a lot
Pedro
99
