Community Member
vpning in and then asdm or ssh
ciscoasa# sh run
: Saved
ASA Version 8.0(2)
hostname ciscoasa
enable password xxx
names
interface Ethernet0/0
nameif outside
security-level 0
ip address internet_ip 255.255.255.224
interface Ethernet0/1
nameif inside
security-level 100
ip address 172.17.193.1 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
management-only
passwd xxx
ftp mode passive
clock timezone mst -7
access-list split_tunnel_list standard permit 172.17.193.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip 172.17.193.0 255.255.255.0 192.168.10.0 255.255.255.0
access-list outside_access_in extended permit tcp any host internet_ip eq www
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu management 1500
ip local pool vpnuserspool 192.168.10.101-192.168.10.254 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-602.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound
nat (inside) 1 172.17.193.0 255.255.255.0
static (inside,outside) tcp interface www 172.17.193.101 www netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 isp_gateway 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
aaa authentication ssh console LOCAL
http server enable
http internet_ip_2 255.255.255.255 outside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
no crypto isakmp nat-traversal
telnet timeout 5
ssh scopy enable
ssh internet_ip_2 255.255.255.255 outside
ssh timeout 60
console timeout 0
dhcpd address 172.17.193.101-172.17.193.254 inside
dhcpd dns dns_1 dns_2 interface inside
dhcpd enable inside
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
webvpn
enable outside
svc image disk0:/anyconnect-win-2.2.0133-k9.pkg 1
svc enable
group-policy vpnuserspolicy internal
group-policy vpnuserspolicy attributes
vpn-tunnel-protocol svc webvpn
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel_list
address-pools value vpnuserspool
username admin password xxx encrypted privilege 15
username vpnuser1 password xxx encrypted
username vpnuser1 attributes
vpn-group-policy vpnuserspolicy
prompt hostname context
Cryptochecksum:xxx
: end
Community Member
Re: vpning in and then asdm or ssh
VPN works. What I want to do is vpning into the device as admin, and then load up ssh or asdm and connect to the device (presumably 172.17.193.1 since that's the inside interface).
I tried:
ssh 192.168.10.0 255.255.255.0 outside
http 192.168.10.0 255.255.255.0 outside
but it doesn't work.
Community Member
The best way to do this is to just have a single internal host that can access the SSH/ASDM. Allow RDP(Windows Box) or SSH (*nix box) access to it. This does not give blanket access to a huge range of IP's, much more secure.
But if you do wish to do it the other way, you are going to have to add and entry to your ACL:
access-list outside_access_in extended permit tcp 192.168.10.0 255.255.255.0 host 172.17.193.1 eq ssh and https
or
access-list outside_access_in extended permit ip 192.168.10.0 255.255.255.0 host 172.17.193.0 255.255.255.0
You will also need a nat exempt for source 192.168.10.0 destination 172.17.193.0
hope this helps.
Community Member
I did this:
access-list outside_access_in extended permit ip 192.168.10.0 255.255.255.0 host 172.17.193.1
ssh 192.168.10.0 255.255.255.0 inside
nat (outside) 0 access-list outside_access_in
ssh didn't work. Getting
3 Jun 25 2008 15:46:23 710003 192.168.10.101 172.17.193.1 TCP access denied by ACL from 192.168.10.101/1269 to outside:172.17.193.1/22
138
