Community Member
VRF, GRE and IPSec together
We manage de WAN for several customers. The branch offices are connected through a no secure network with GRE tunnels. The GRE tunnels are protected with IPSec. The tunnels are terminated on a Cisco 7206 VXR.
Now I have to the integrated firewall between the branch offices and corporate resources. The corporate resources are used by all customers. I have to install one firewall by customer.
I try to use VRF-lite (Multi-VRF) on the 7206 for separate each customer on a VRF instance and forward the branch offices flow on the right firewall.
With VRF-lite configured, the GRE tunnels go down when I put IPSec. But GRE and VRF works fine without IPSec. And GRE and IPSEc works fine without VRF.
Is somebody used successfully VRF-lite, GRE and IPSec together?
Thanks for your help.
! ### Cisco 7206 VXR Configuration Resume ###
ip vrf bc1
rd 1:1
crypto isakmp policy 10
encr 3des
group 5
lifetime 14400
crypto isakmp keepalive 15
crypto ipsec transform-set uni_set esp-3des esp-sha-hmac
mode transport
crypto map unicible_lab 10 ipsec-isakmp
set peer
set transform-set uni_set
match address gre_unicible_lab
interface Loopback2
ip vrf forwarding bc1
ip address
interface Tunnel201
bandwidth 2048
ip unnumbered Loopback2
ip mtu 1420
keepalive 2 3
tunnel source GigabitEthernet0/2.2
tunnel destination
tunnel vrf bc1
interface GigabitEthernet0/2.2
encapsulation dot1Q 601
ip address
ip route
ip route vrf bc1
ip access-list extended gre_unicible_lab
permit gre host host
