VRRP vs Load-balancing with VPN 3030
I'm trying to determine the advantadges of using Load-balancing instead of VRRP with two VPN 3030 concentrators.
Any help would be greatly appreciated.
Bronze
Re: VRRP vs Load-balancing with VPN 3030
The only real advantage I know of is that Load-balancing will load balance your client to lan connections so if one 3030 fails, only users on that 3030 will be dropped and will have to reconnect.
Other than that each solution is pretty much the same, except for configuration of course.
Hope that helps.
Thank You for your response. I can't understand whether the two VPN concentrators will use the same address pools and have the same users and groups configured (locally or on a remote AAA server) when in load-balancing configuration.
Thanks in advance,
Lora
217
