05-06-2007 10:00 PM - edited 03-09-2019 05:56 PM
I want to block P2P application & IM using ASA with IPS built-in. I dont wanna use the ACL for all the ports because most of the P2P application using dynamic ports.
05-07-2007 07:48 AM
I think that if you don't want to use ACLs then you are going to need a 3rd party appliance such as the Packeteer. I would like at this option even if you can block without ACL. I know my life has been made considerably easier since the introduction of the Packeteer Appliance.
05-07-2007 09:06 AM
Aamir,
You can do this using the application layer inspection on the firewall.
Please take a look at the configuration guide given below.
Rate this post, if it helps.
Cheers
Gilbert
