08-15-2006 09:03 AM - edited 03-09-2019 03:54 PM
I need to modify a connection entry but get this message. How do I get 'write priviliges'?
08-21-2006 08:42 AM
No need of any write priviliges.There are some options through which modifications to an Entry could be done.Refer the URL
http://www.cisco.com/en/US/products/sw/secursw/ps2308/products_user_guide_chapter09186a008031f1b2.html#wp1054769 for more info.
08-22-2006 08:08 AM
Can you see the file in Windows explorer?
Right click on it and choose PROPERTIES.
Should be a check box at the bottom for READY ONLY, etc...make sure everything is unchecked and try again.
If you are from the old DOS days, you can find the file in DOS and run the ATTRIB command on it...
c:\attrib filename.123 -r -a -s -h
see if that helps.
08-22-2006 11:29 AM
Thank you.
