Wccp
Hello I am setting up a transparent proxy with wccp/cisco ASA and squid with Linux, the same configuration works with a router 3800. wccpv1 and wccpv2, but does not work with cisco ASA, the following configuration
wccp web-cache redirect-list fluxo-http
wccp interface inside web-cache redirect in
access-list fluxo-http extended permit tcp any any eq www
regards
Re: Wccp
Barbosa, I have the same problem, how did you solved your problem?? Can you share the actions you made??
Re: Wccp
Hi perez,
I was using the version 8.04 and make a downgrade to version 8.03 and the same commands works. I open a TAC into Cisco, i met an engineer and is analyzing the case, seems to be a bug. But once you get a response from the support of Cisco tell here in netpro forum.
regards
289
