WebVPN and Exchange 5.5 OWA
We are testing our Outlook Web Access through WebVPN. OWA is running on Windows 2000, Exchange 5.5 SP4. I can logon to OWA with out any problem and read my email and navigate through the folders and calendar with out any problem. When i try sending a new email or reply existing email it does not work. Did any one encounter this problem?
Re: WebVPN and Exchange 5.5 OWA
Looks like got a similar problem. Any update on this
Mail guard is turned on by default on ur PIX. Test it with mail guard turned off on ur PIX i.e
no fixup protocol smtp
Microsofts implemetation of SMTP is not RFC 821 compliant and this causes the PIX to mislead the clients into believing SMTP extensions are supported which inturn get blocked by the PIX.
Let me know if it resolves ur problem.
Cheers
It's running on Cisco 3030 not on PIX
Did you get a solution to this? I have a client with the same problem.
I believe Cisco is not going to fix the problem any time soon (may not fix at all). Here the Bug ID and status: CSCed79598. You can refer your TAC case to this bug ID. If more TAC cases are open, they may change the priority of the bug.
Chandra
i have upgraded code to 4.1.5. It seems working. I am going to some more testing.
135
