WebVPN capture tool
After enabling the WebVPN capture tool the supposed system generated files (mangle.* & original.*) are not getting generated at all.
Did we miss something related to logs?
Any idea? TIA.
Silver
Re: WebVPN capture tool
I think you should check if you are using correct group username and password. Following links may help you
http://www.cisco.com/en/US/docs/security/asa/asa70/configuration/guide/webvpn.html#wp1071129
The client is using a VPN Concentrator Rel 4.7. The url points to ASA.
Thanks.
298
