WebVPN connection disrupted
Im using the webvpn to connect from 3 different networks using the same laptop. 2 of them works fine but in one of them i cant connect and I receive thi message: "The SSL VPN connection to the remote peer was disrupted and could not be automatically re-establisehd. ......". The only difference that i could tell is that from this network we use a proxy.
any clue?
1 REPLY
Re: WebVPN connection disrupted
Your problem could be related to cisco bug CSCsg37651. Also if you are using ASA upgrade the SVC to latest version.
106
