Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
webvpn homepage links
Configured webvpn homepage via quick start. After login, banner appears, but links do not. Have enabled file access under Groups and listed links under Servers and URLS. Why don't the links appear on the Homepage?
Silver
Re: webvpn homepage links
WebVPN on a concentrator needs to be configured at a couple of places, under the "Interfaces" and "Tunnelling and Security" sections of the configuration. Following sections will help you in getting the configuration right.
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/config/tunnel.htm#1309313
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/config/webvpnap.htm
Thanks for your help, but I failed to mention that every other feature of the webvpn ssl connection works except for the homepage links. However, I carefully read through the info you referred me to and found that I had configured everything correctly.
103
