webvpn port forwarding
I do not understand how this works. I set a port forwarding in the VPN3000 for port 23 and I started application access, but how do I then telnet to the remote machine???
Re: webvpn port forwarding
When you see the Application Access popup window, you will see a configured loopback address 172.0.0.x and a port number. You will have to telnet using the loopback and the port number. Let's say the port number is 36500
You can use Putty software or on a Windows Command Prompt, type:
telnet 172.0.0.1 35600
Let me know if it worked.
You are a peach. I would never have thought of that in a million years. Works just fine
101
