WebVpn using terminal services with netware client
Has anyone had luck using terminal services through WebVpn on a machine that has a netware client 4.90sp1a on it to a windows 2000 server?
I get prompted with a netware login to login to the W2K server even though netware is not installed on the server.
1 REPLY
Silver
Re: WebVpn using terminal services with netware client
Make sure that you are running the FCS release of 4.1 and not Beta. WebVPN doesn't support Java, ActiveX, or Flash I guess. If you are running any applications that use any of the mentioned then it will not work.
84
