Community Member
WebVPN using VPNC
Our client is having an issue while accessing webvpn using SSL VPN client, the message prompt...
"The SSL VPN Client was unable to successfully verify the IP forwarding table modifications. An SSL VPN connection will not be established."
Any idea? TIA.
Bronze
Re: WebVPN using VPNC
Did you created the VPN through WEB VPN wizard on SDM? is it a router?
Community Member
Community Member
On an ASA you can get this message if you configure a Split Tunnel ACL as an extended ACL with protocol and port constraints.
Split tunnel ACL's are typicly standard, you would then use the vpn-filter and an extended ACL to restrict the traffic.
510
