WebVPN with SSL sites
We can get to our internal SSL sites through the WebVPN on our 3005 but they do not display properly and hang on some Java based applications. Pix PDM, WLSE interface, and call manager will not display properly. It seems as if the images are gone (and this is not selected on the 3005 to strip the images out.) Everything displays properly on http sites.
Silver
Re: WebVPN with SSL sites
WebVPN and Java applets have a few issues together. Please see CSCed72835 'WebVPN: java fails if url entered instead of remote server hostname' and CSCec78536 'WebVPN does not properly support some Java applets'.
I noticed a simialar problems using the WebVPN. We have a web portal that uses Microsofts share point. I set up a port foward using the ip address of the server and the some of the page graphics would not load correctly and some of the links did not work. This was because some of the links and graphics were pointing to the root of the page and some had the full path. I changed the port forward to use the dns name and this fixed the problems. Still no luck using https sites though.
122
